The pipe mounting scheme is overly complicated. Including the double wall nozzle .
Copy the SB pipe mounting system if you can. And check the pipe wall thickness. They increased it dramatically, fairly early on.
The single biggest thing you can do is change out the landing gear (including moving the inner door cylinders). How are you going to get the purple gear into the wings?
Oh reinforce the cowl to fuselage joints from the inside too
