Spent my last days here in Utah getting the fuse done and wing along with air scoop and front wing filler.
The front scoop I just used 3/16" balsa frame work with 1/8" sheeting reinforced with tri-stock and 1/4x1/4 as well.
I will glue this piece to the wing once it is covered.
The front filler part of the wing/fuse area I used solid balsa stock, shaped it and glued it directly to wing.
I feel pretty good about the amount of work done in this trip.
Basically what is now left is the filling and sanding prior to monokoting.
I once again also had to take a peek at what it looks like so far along .... I know I know Im a new beginner builder and couldnt resist seeing some fruit from my labor.
Now its time to get back to some races, and more traveling for work.
