Bent Wing Tube
Before you hastily order that CF replacement, know that the failure method for a CF tube is to BREAK, not bend. I some instances, you will get a bent tube back onto the ground, I don't know about a broken CF tube.
Granted the CF is (hopefully) going to be stronger.
Kevin
