Originally Posted by
bluelevel
Any word on the K-100TP that was first mentioned in 2013 but is still not available? Have you guys tested more props on the K-60TP?
I have tried the SEP 24x22 three-blade prop, but was not able to spin it higher than 3500 rpms. Tach may have been the issue. Also ran the Biela 24x22 three-blade prop which seemed to have much higher rpms, closer to 4750. Haven't run the engine since late October, but plan to get back to it by April. Will let you know how the PC-21 performs with the Biela prop, don't plan to use the SEP prop.
