Originally Posted by
coreyg
Its funny reading the comments actually. The aim wasnt to get comments about my hornet as it stands now, because I can assure you it would probably s**t over skymaster. The point was simply to show what i have found prior to all my work and for others who wish to buy FEJ, to really look over their models thoroughly.
In saying that, despite the reputation of other companies, you would be an absolute idiot to not go over any model, regardless of the brand. Even skymaster has weak crap coming out of their factory for which ive seen
So you're saying that you cut open the wings and tails and reinforced the sub-standard construction in there as well? If you've read all of the threads on FEJ and sen them fly and come apart, you will realize that most of the failures occur in those areas. Also, have you check the pivot points of the stabilators? Previous experience documented on here indicates that those are incorrectly placed and its unclear if they have moved these to the correct location...
Bob
