RCU Forums - View Single Post - Engine/Radio selection
Old 03-13-2016 | 01:08 PM
Y3kim
Originally Posted by Calvinman
Keep in mind during the build to use a shaft or somthing to link the rudder down to where the tail wheel will be so it will steer. Alternately you can us a pull pull system off of the rudder servo to steer the tailwheel with. I have my Tiger's tailwheel freewheeling as the thread broke for my pull pull set up. it works, but if there is any wind taxiing to the runway and back to yourself and the pits is out of the question.
Did some looking I think Ill use the "Sullivan tail wheel bracket 20-40" for steering, unless someone recommends a better one.
this is slightly OT but Is there a preferred battery type for airplanes? I see a few different kinds, not really sure on what type I should get, and will I need 1 or 2 ?
Mike
