A 4.8 v 2000 mAh battery is what you will need for the airplane as well. One of those in the transmitter and one in the airplane will let you fly for 2 or 3 hours. (12 to 18 ten minute flights.) If you use redundant batteries in the airplane, you can use lower capacity batteries totaling 2000 mAh or more with the same result.
