RCU Forums - View Single Post - Engine/Radio selection
Old 03-14-2016 | 01:28 AM
Y3kim
Originally Posted by jrf
A 4.8 v 2000 mAh battery is what you will need for the airplane as well. One of those in the transmitter and one in the airplane will let you fly for 2 or 3 hours. (12 to 18 ten minute flights.) If you use redundant batteries in the airplane, you can use lower capacity batteries totaling 2000 mAh or more with the same result.
Oh wow I didnt know they lasted that long thats nice
Originally Posted by loopdeeloop
One of our club trainers is that exact airplane it flies very nicely with an O.S. 40 LA (no longer available) but the O.S. 46LA I believe still is. These are entry level engines and you will be told to use any number of engines from what I just mentioned to a Saito 4-stroke. This is your first airplane - It will be taking some lumps and bumps so you don't need a high end engine. You will likely find a bunch of these engines new and used on E-bay or in the Buy&Sell area of this site. A radio is another matter. Definitely a 2.4 GHz "programmable" is highly recommended. You will likely end up with more than one airplane making the radio key to your happiness. Futaba, JR, Spektrum, and all the others offer what you need. 6 or 7 channels will suit your needs for a long while. If you get into warbirds where you have flaps, retracts, bomb drops, and bomb bay doors you obviously need lots of channels so 8 or more is in order. More channels = significantly more money. Research your needs thoroughly. But just getting started you can get buy with a simple 4-channel Tactic.
I would definitely like an OS for ease of use but Ill probably have to settle for a Chinese engine , Ive already ordered the Tactic TTX850 but am undecided on an engine. the eagle 2 kit is due to arrive today
