RE: Electrical solder
Goldwing- The numbers 63/37 represent the alloy component percentage. In your case 63% tin, 37% lead. You mentioned a new tip. I presume that you 'tinned' it before hand. You may also need to clean your solder, I fold a small piece of sandpaper over the solder and pull it through a few times. If all else fails, you might try acid core solder. Jim
