Originally Posted by
jaka
Hi!
As I said 11 years ago I use Ca glue for most of my building.I never use 30min epoxy! Glue epoxy is messy and heavy and is very hard to sand.
The bonding strenght of All glues is so good that it's not the glue it self that breaks. What's important is how the wooden parts fit! In your case gluing the fin to a sport airplane ordinary thin or medium Ca could be used and of course accellerator, thats a must!
wow! You are serious, sounds like to me. No way I would ever glue a fin on a 40% airplane, weighs 46 pounds, with CA glue! The fin has foam under it as well. it is foam sheeted by balsa.
Only glue to use would be Titebond III, poly-urethane glue, or epoxy glue. MY question was whether epoxy resin is as good as 30 minute epoxy, I was never asking and would never consider, and do not know of anyone that would build a 40% aircraft with CA glue. Best regards
Cam
