Frazer, thank you for checking in.
No the build is not over. I have been logging the build on RCSB. In December I decided to do a build thread over there also.
http://www.rcscalebuilder.com/forum/...TID=24377&PN=1 You must register if you wish to view the thread. That is free. You must be a paying member to post more than 5 times. 20 dollars a year.
Originally I was going to do dual threads. Then RCU began to go adds crazy and interest here seemed to go cold. It took 3 months for anyone to care to ask about the build. It takes effort and time to log a build thread. It takes more time to do two.
Pete, thank you. It will go the distance for sure. With spring now here the build will slow down some. My guess completion some time in early 2017. That would make it a two year build.
Here are a few pics of where the build is at to date.
Gear mounts and inner cowl. Inner cowl was made with a plug, then mold, then layup.
The inner cowl ring will get scribed around the gear fairing and wing LE and end up stopping at the first belly pan former.
Kevin
