RCU Forums - View Single Post - GJC/FB 2.5M Viper Build
Thread
03-20-2016, 03:02 PM
47
FenderBean
A little more done today, got to try out my new ban saw. Its so easy to cut the thick ply now, cant believe I waited so long to buy one. Turbine is in and connected, I have the pipe set just need to drill two holes for the brackets on the end of the turbine rails. I made two 1/4 ply to make the turbine fit, easy to remove the turbine for sure. I also hooked all the airlines in the turbine bay up and tested them all systems are go there. I need to get the servo wire ran to the pb boxes now so I can install the pipe, this will leave final setup, light install and canopy bucket mounting to the canopy.
Tail cone is held on with four 3mm bolts and it supports the pipe.
Reply
Like
FenderBean
View Public Profile
Send a private message to FenderBean
Visit FenderBean's homepage!
Find More Posts by FenderBean
View iTrader Profile
