RCU Forums - View Single Post - Xicoy ecus Telemetry!
Old 03-21-2016 | 01:37 AM
Gaspar's Avatar
Gaspar
Originally Posted by Edgar Perez
Interested on using this with Weatronic Bat 60. I could not see the hardware connections. Where does the unit connect to? Mux-Box, LinkVario, other?
Is there anything else needed?
Thanks.
The Flight Computer connects directly to the Wea receiver in the SCU port. ATTENTION: the connection lead is not "straight", the Wea RX, contrary to all other telemetry receivers, receives the data using the central pin, so the red lead should be cut on the connector that plugs in the RX, and the orange moved to the center pin. Contact me directly if any doubt.
Gaspar
