RCU Forums - View Single Post - Contra Rotating Propeller Drive for f3a 2m Pattern Planes
Old 03-21-2016 | 05:49 AM
  #1598
Bubblehead575
Originally Posted by Bubblehead575
Peter
I just maidened my Agenda with the V4 and Spin 99
Unfortunately it only lasted about a minute, the Spin 99 went up in smoke. I have used Castles with all my 14 pole Hackers without issue, but had a Spin 99 I bought 2 yrs ago for a Pletty that was smoking Castle ESC's So when Brenner said there might be issues with a Castle, I used it instead. I have a Castle HV 120 that I am going to try next. Unless Brenner tells me it will smoke also I will give it a try.
Bill
Update
I went with the Mezon 95 and got in 5 solid flights, I checked the current draw on the ground, and was drawing only about 85 amps, Which is consistent with the use of the Throttle Tech. And to add my 2 cents about the power, Lets just say WOW. I am going to have to learn to fly with a lot less throttle.
Brenner
Just a question here to determine if I might have an issue.
Flew it in 45-50 deg F temps and checked the temp of motor and ESC on landing. The ESC was literally stone cold, barely warm, the Motor was showing 155 deg F Based on what you have been saying about the how cool they run, it seems a little hot. It didn't seem to vary even when I was pushing it a little and pulled close to 4000 mah out of my packs, I did notice some grease weeping out between the Front Hub and Rear Spinner. Otherwise no, drag or anything unusual
