RCU Forums - View Single Post - New Decathlons From Seagull 91 and 120 Size!
Old 03-22-2016 | 01:13 AM
  #358
swannyuk88
I've installed a Dubro semi-scale tailwheel. Unfortunately it wouldn't work straight out the box as the arms on the rudder bracket were hitting the end of the fuselage (it's quite a bit wider than the rudder) I had to lower the whole tail assembly using balsa but it ended up working really well.
ID:	2153686   Click image for larger version
