Originally Posted by
IFLYBVM2
Question for all you 1/5 SM guys :
I know that the overall height of the servos have to be adjusted to get the bearing to line up properly with the surfaces. Would it be OK to shim the bearing up on the servo arm with washers instead of shimming the servo itself ? Any negatives to doing that way ?
Thanks-Mike O.
Mike, are you using the rubber grommets for the servo screws? If so, scrap those and just go direct screws and washer. I just added washers underneath the servo to get the correct alignment.
Also, what Arms are you using? I went with the MPI's and really had no height issues, other than some canting with a thin washer or two to get the correct angle.
Rex
