RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 03-25-2016 | 07:39 AM
  #2953
HoundDog's Avatar
HoundDog
My Feedback: (49)
Originally Posted by Hydro Junkie
Not likely. ATC is basically the ones that keep planes away from each other. When you think about it, small planes probably aren't going to have most of the hi-tech stuff, they will need to have someone "assisting" them. What worries me is that the FAA may require us to have two way communications with ATC to prevent accidents as well
Hydro as U probably already Know the only separation of air craft the ATC is required to keep separation are those on an Instrument Flight Plan and only when in IMC. Not with standing they do try (On a workLoad Basics) try to keep other s advised of other aircraft but it is not their Job. It is still the pilots responsibility under the "Seen & Be seen concept) that the ATC system works. At least until after 1 Jan 2020 when all aircraft in controlled air space is mandated to have ADS-B Automatic Dependent Surveillance-Broadcast.
