RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 03-25-2016 | 02:16 PM
  #2958
HoundDog's Avatar
HoundDog
My Feedback: (49)
Originally Posted by Hydro Junkie
Agreed but, with a quad, THE OPERATOR ISN'T FLYING EITHER VFR OR IFR. If some one is flying LOS they wont be high enough to be and issue to aircraft so there won't be a need for ATC to be involved. That being said, if the operator has no instrumentation to fly by they can't be flying IFR. FPV isn't VFR compliant either so, that being said, ATC is powerless to do anything other than warn others the quad is there. I see this requiring quad operators to be required to have two way communication with ATC to prevent collisions in the not too distant future
Maybe for big professional/commercial Drones But all is needed is an ADS-B transmitter and all full scale aircraft will/can avoid any interaction with Hobby Drones. All a person needs is one that is transferable between aircraft (Drones). Like I stated before if a club had one on say a 20 foot pole they could broad cast their position and full scale would avoid the area. Problem solved. Besides if U check some of my posts about FAR 91.119(b), Then it's the full scale plane is required to circumnavigate any place there is an open air assembly of people by a minimum of 2000' horizontally or a thousand + feet. It worked when I referenced 91.119(b) to the local flight school head instructor low over flight have seized by almost 99%. Planes have been above 1640' 500 meters.
