Originally Posted by
marc s
Wim,
It would be possible to add Festo fittings, the reason I don't fit them to the CAT range is mainly due to two things.
Firstly they are more suited to pressure applications rather than suction, and secondly being a complex fitting there is a bigger chance something will fail resulting in an air leak. A barb is like a key, its simple and very good at its job if correctly used/designed. A pipe pushed over a barb and security wired will in my opinion be far more reliable than any push fit type fitting.
Wim, appreciate your support and happy safe flying.
marcs
Dear Marc,
Don't you DARE put festo's on your beautiful CAT's!!!
