I was going to get the Balsa USA 1/3 Cub at the Toledo show. After seeing the Sig super Rascal I was hooked. The way the fuselage is assemble makes building very easy. Once the fuselage is put together just glue all the the formers and break off the tabs. The wing is 3 piece, the center section that bolts to the fuselage and has the flaps, and the outer wing panels has the ailerons and is hold in with wing tubes. I going with my OS Pegasus 320 for power. I pre ordered mine with late summer or early fall delivery.
