RCU Forums - View Single Post - Engine Syncronizers which is better D&L "Twinsync" or OSA " MicroSync"
Old 04-08-2016 | 03:49 PM
bentwings
If you are going to test the engine sync once it is set up, fill the tank on one side and only put a little in the other. Run them at full throttle and see what happens. Let your helper select the fuel combination without telling you....see if you can react correctly and fast enough. Maybe have a plan and try to follow it.
