Originally Posted by
iflircaircraft
Ok, so when a maneuver is completed there is no definitive altitude when exiting such maneuver as long as it is parallel to the ground?
Each maneuver is entered and exited from level flight. Got it.
Correct. Some figures like a loop require the same entry and exit altitude, others like a hammerhead do not. And the top of each figure is not all required to be the same from figure to figure.
If you are serious about flying IMAC I strongly suggest that you download the rule book and take a look at the actual rules.
https://www.modelaircraft.org/files/...Aerobatics.pdf
