Originally Posted by
Neko
Nearly finished with my build. One disturbing thing. When I installed the stabs, I carefully aligned them so that the tip of each stab was equally distant from the tip of the wing. As a result, the stabs are not that well aligned with the fuse itself. The space between the stab and side of the fuse is a bit wedge-shaped. I don't suppose it will make that much difference, but it triggers my OCD.
Any suggestions on starting throws?
David
Hi
on mine I also got some Space beween the fuse and stab but mostly on one side , what I did was make a balsa wedge and cower it with some film , just be careful so it move freely after.
pretty quick fix .
