Compared to the CB200 you will loose the short protection for each servos and will be using only one battery directly to the Rx so you will loose redundancy unless you set up an other system to feed the Rx with 2 batteries.
Telemetry wise with the CB200 you can plug up to 3 devices, with your system not sure what you will have I do not know which channel can be converted to telemetry on the R14
