Originally Posted by
bri6672
Yes that would be fine. I plan on extending the hinge wire holes thru the rail to avoid taking the rails off unless for service..
That's what I did with mine. My rails will stay put. Be careful where you set your rear screws for the rail to the wing, not to get in the way of where the hinge wire needs to exit through the rail. Just a heads up on that little item
Rex
