RCU Forums - View Single Post - Aileron help!
Old 10-22-2003 | 11:15 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Aileron help!
If you use the debonder method, new hinges won't stick properly.
After replacing them, drill a hole through each side of each hinge and glue in a tooth pick. Then cut the tooth picks flush with the wing. (Use round tooth picks)
