Originally Posted by
RCISFUN
Just a thought....So I would guess this would also work in reverse, i.e. when the throttle is lowered the flaps are deployed from 1/2 to full, this can be a dangerous situation... when I first started flying jets with a Boomerang I tried this thinking this would be a great idea...can you say slow down to snap!
If you can program to prevent that from happening ( i.e. in one drection only) then no problem...
For or a go around you could set the throttle activation higher. May 3/4 throttle. That should give a buffer area.
