Originally Posted by
jonkoppisch
Need logic switch help. For some reason I've gone brain dead lol
Id like to make a logic setup that my flaps will raise from full flap to 1/2 flap when the throttle goes over 1/2
I believe I accomplished what you are after by using a throttle to flap mix. I trigger the mix using a logic switch set to flaps <65% or a slider position of <-35%. The mix is set to 100% with a single direction selected. I then used a 7 point curve in the mix so the throttle only effects the flap setting above 75% throttle. The result is if I have to do a go around I can advance the throttle to full with landing (full) flaps and the flaps will automatically retract to my takeoff flap position. The throttle does not affect the flap position if the logic switch is not active. I think it works well.
Tim
Reason: Typo
