Originally Posted by
Alex48
...The weight of the empty airframe plus gear is 29lbs 14oz which leaves 14lbs2oz for all the equipment if it's to be kept under the 20kg limit here in the UK. A tall order I think so its been registered with the LMA's over 20kg scheme and such the radio will be a PB Royal with two Spektrum 12000 receivers...
Does anyone know if the G2 air frame with gear is lighter than the 29lb reported in post 1?
Thx in advance for any input
Regards
