I wish I had seen this reply before I tryd thicker fluid in the front. Bad move. Your exactly right it made the car steer worse and didn't do anything with torque distribution to the front lol. Its ok I changed it back to stock and decided I'll go thru 2 sets of fronts to 1 set of rear tires. The tires on the front were wearing pretty even across though. Maybe a little more in the middle at first but other then that pretty even. I'll go with the good advice next time and change the center diff fluid. We'll see what happens. Maybe its the tires also. If that's the case then PL Blockades really hold up good and PL Crimefighters wear out fast.
