Looks good, hope it works out for you, but don't be surprised if something else cracks on a hard landing. Mine tends to land hard at times, and if it weren't for the give the gear has, pretty sure something would have cracked or busted by now.
My SIG Cub on its maiden flight landed hard, and its gear is not as giving as the 4*, and when it hit I heard something crack, sure enough the wing mount on the fuse busted right where it joins to a former. The worse that can happen with my 4* is the prop clips the ground and kills the engine.
