RCU Forums - View Single Post - receiver padding
Old 04-18-2016 | 11:59 AM
fly24-7's Avatar
fly24-7
I've used velcro with mine. The hook n loop arrangement dampens the vibration well enough. I've never had a received go bad from this mounting method nor has one come loose. One note though, I've only used 7 channel or smaller. If you're using a larger receiver, you may want to consider a velcro strap (or wire tie) with a small foam pad underneath.
