RE: Do I really need a choke?
You will probably be able to get by with out a choke when using an electric starter. If you will choke the engine with the ignition switch on, it will not flood as easy. It will try to run, but wont and then you can turn off the choke and fire it up.
Besides, what if the starter quits due to a dead battery or something?
