This is what happens when you elbow your bulk head as hard as you can doing something else. I started to box in the hatch area. The sides of the box are hooked under the wing spare with a couple of gussets to stiffen things up. The hatch will be material doubled up inside this area. It will be cut out after everything is sheeted and shaped. I also hacksawed some slices for the stringer locations.
