RCU Forums - View Single Post - Xicoy ecus Telemetry!
Old 04-20-2016 | 12:57 PM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by JoeJr1485
Okay so I have the flight computer plus. When looking at the connections, Thro output 1/2, thro input, telem out, eng 1/2 do I plug my throttle output from my CB200 into the thro input into the flight computer then from thro output 1 to my ECU? then connect the telem output from the flight computer to my CB200? I want to make sure I have my connections right. would it be better to have the xicoy GPS or the Jeti GPS??
I haven't installed one yet myself but I have one on order so from the instructions I think you (and I) will need the following connections.
Telemetry output - Connect to your CB200 EXT port (or EXT1 or EXT2).
Eng1 - Connect to ECUs data terminal port in place of the data terminal.
IF you are using an external module such as a GPS, etc, you will need an extra power connection. Connect "Throttle In" to any unused receiver or Powerbox port, not your throttle channel. Only power connections (no signal) needed. If you aren't powering any extra modules from the FC1, I think you can simply leave "Throttle In" disconnected.
The other connections appear to for future updates to support twin engines, etc.
Your receivers throttle channel should be connected to the ECU.
At least that is how I plan on connecting mine when it arrives. Hopefully if I'm wrong, someone will correct me.
