RCU Forums - View Single Post - Xicoy ecus Telemetry!
Old 04-20-2016 | 02:25 PM
JoeJr1485
Originally Posted by wfield0455
I haven't installed one yet myself but I have one on order so from the instructions I think you (and I) will need the following connections.
Telemetry output - Connect to your CB200 EXT port (or EXT1 or EXT2).
Eng1 - Connect to ECUs data terminal port in place of the data terminal.
IF you are using an external module such as a GPS, etc, you will need an extra power connection. Connect "Throttle In" to any unused receiver or Powerbox port, not your throttle channel. Only power connections (no signal) needed. If you aren't powering any extra modules from the FC1, I think you can simply leave "Throttle In" disconnected.
The other connections appear to for future updates to support twin engines, etc.
Your receivers throttle channel should be connected to the ECU.
At least that is how I plan on connecting mine when it arrives. Hopefully if I'm wrong, someone will correct me.
Thanks Wayne. That helps me a lot. I didn't know if was supposed to connect my throttle connection into the FC1 and then from the FC1 to the ECU to control the throttle response to the turbine.
