Originally Posted by
vespino67
Hello Craig
are you using a pneumatic fail-safe with your Power Box configuration?
I decided not to use a fail safe for a couple of reasons. First the gear is held up by air pressure and is pretty heavy which will allow it to free fall down. The second is the gear is designed with a new locking cylinder that locks the gear in the down position. In the event of a pressure loss the gear would drop out and all it would take is a little cross control input to lock um in place.
