Yes - I've had two of these models. The model is VERY scale and flies very well indeed. Since its True scale, the nose is a lot heavier than one finds in the usual "standoff scale" models from other manufacturers. Flying characteristics are affected very adversely if the CG is set even a little too far back, so one has to be careful. However, follow the CG instructions and you'll love the model. Get it - it's the only true-scale CAP 232 RC model around... I've currently got a Laser 360 V-Twin in it and I use a 22x8 or 22x10 prop (interchangeably).
