RCU Forums - View Single Post - How to make perfect wing saddles
Old 10-22-2003 | 02:23 PM
csmbt
Default RE: How to make perfect wing saddles
Yea no more wing saddle gaps My 1st foray with micro baloons and epoxy
went well , one thing I did find though which I will pass on is make sure
if you use seran wrap it is nice and TAUT on the wing otherwise you get
a lovely imprint of the ripples in the plastic. Being a belt and suspenders
kind of guy I also used foam tape to finish after covering which gives it
a nice tight fit and also looks a little better ( unrelted advice the glue
backing on foam tape lifts off the second it even smells glow fuel so
I always attach it on the covering using CA ) Thanks for all the helpful
advice guys
