Originally Posted by
warhwk
Second flight with a used (Ebay) Magnum two-stroke 91. Engine lost power then dead sticked. Back on the bench I noticed the glow plug was pointing a bit off-center. I took the glow plug off, but could not find any issue with it. When I tried to start the engine on the bench, the glow plug ignitor shot off with the glow plug still attached.
When I looked closer, the glow plug thread insert had come out of the head!!
I first thought it was a defective heli-coil repair, but I could see the insert is press fit into the head and is shaped like a Torx socket. It may have been spot welded as well.
I don't have anything to lose by trying JB weld, but I don't want anyone standing next to the engine when it is started.
Has anyone seen something similar?
Yes cracked carb collar, broken idle needle valve. Both broke very easily and both on Magnum engines. Poor CQ on metal process.
