RCU Forums - View Single Post - DLE 20cc unable to idle low enough
Old 04-27-2016 | 10:53 AM
pilotpete2's Avatar
pilotpete2
Originally Posted by RAPPTOR
why 1/4 throttle when ..black out""?? "fail safe" should have put throttle to idle !!?? If,, you did, bind with idle setting
Not how Futaba failsafe settings are set. With Futaba, F/S settings are set in the failsafe menu for each model setup. The only exception is when one is using a conversion module in an older non 2.4Ghz transmitter, then throttle F/S is set when linking the receiver ala Spektrum.
Pete
