RCU Forums - View Single Post - Glow engine hesitates when going to full throttle.
Old 04-28-2016 | 04:45 PM
HighPlains
Disagree all you want. I'm telling you how it really works, idling in the air the engine is unloaded because the prop is not mostly stalled out like it is on the ground. If the engine is turning faster, it also has more suction, thus a larger pressure differential, so you get a higher flow.
