RCU Forums - View Single Post - DLE 20cc unable to idle low enough
Old 04-28-2016 | 09:13 PM
av8tor1977's Avatar
av8tor1977
Good advice. However, if it is a fairly large air leak, it might not run with the high speed needle closed even if the low speed carb circuit is functioning properly. When I rebuild a carb, I ALWAYS squirt WD-40 through every single circuit to verify that it is open and flowing.
AV8TOR
