RCU Forums - View Single Post - DLE 20cc unable to idle low enough
Old 04-30-2016 | 01:56 PM
FL@T_SPIN
Carb
1. Engine removed
2. Carb removed
3. Reed valve assembly removed
4. All circuits cleaned out with carb cleaner
5. Throttle plate and choke plate intact and screws tight
6. Screen removed
7. Carb inspected for cracks, varnish and pitting – none found
8. Needles removed, cleaned and checked – no issues
9. Carb allowed to dry why other bits checked
Engine
1. All bolts checked for torque
2. Inspected for any visible damage – none found
3. Barings appear to be good
4. Good compressions found
5. Hall sensor appears to be fully intact – unable to check timing but bracket seems to be in standard middle area
Fuel tank
1. Disassembled
2. New fuel lines, clunks and stopper installed with barbs on brass tubes
3. Leak tested – no leaks found
Carb
1. New screen put in for inlet
2. All gaskets carefully reinstalled
3. Reed valve assembly checked and reinstalled
4. Reinstalled carb
5. Reinstalled engine and fuel lines
6. Needles set to default 1 ½ out on both
Engine start up
1. Setup currently on ibec with a123 batteries from buddyrc fully charged
2. Chocked engine
3. Started right up at ½ throttle and died when brought just one click below ½
4. Needles richened out 1/8 turn increments till engine settled around 4200rpm and dies – low needle now at 4 turns out
5. Muffle removed to rule out any back pressure issues – no change
6. I got the engine to settle down to around 3700 rpm but then promptly died
7. Restart requires choking every time still
8. Tested with carb cleaner around all gasket areas at around 5000rpm – no change until cleaner got to throttle throat
I am wondering if maybe the issue is the timing or the ignition, either this or does anyone want to buy an engine. Anyone have any other thoughts….pulling what hair I have left out on this one
