So,your running 5v on HV servos? You could save some weight by going 8v on the ESC using the Jeti dual switch 10gr and connect the backup battery...on side B, it will go between each input using the highest one so you will be on 2s battery for a short time then remain on ESC the rest of the day....much lighter and smaller...
