Originally Posted by
Dansy
So,your running 5v on HV servos?
Hi,
Yes all Futaba servos I use in my Galactika is High Voltage (HV), and I have BEC voltage in Master Mezon set to 7.4 volt.
Dansy
You could save some weight by going 8v on the ESC using the Jeti dual switch 10gr and connect the backup battery...on side B, it will go between each input using the highest one so you will be on 2s battery for a short time then remain on ESC the rest of the day....much lighter and smaller...
OK, 10 grams for Jeti dual switch. Then I need a 2 cell LiPo also - they may weight for example 18 grams for an Gensace 200 mAh or 10 grams for 160 mAh. Total 28 or 20 grams. Compared to Scorpion Backup Guard 37 grams. 9 or 17 grams savings.
Do You have any link to this Jeti 10 gram dual switch?
/Bo
