Originally Posted by
helifox
Hi George,
Thanks for information, but will try to do inner pushroads as manual sais. Will try to find solution (may be somebody help with pictures). My friend will install JR8911 all around.
Харистополи,
Kind regards,
Sergey
This is what is was trying to say in my previous post.
With 38%-47% end points your aileron servo travel will have very poor resolution in compare to your aileron stick travel.
When set up for maximum resolution(maximum end points)
, the control response is much smootherand more closely matches the precise inputs and intentions of the pilot "
http://www.rcflightschool.com/SetupPDFs/Resolution.pdf
Maybe if you try drill a new hole on your servo arm as closer you can to the servo arm center so you can increase your %-% end points .
The your Aileron feeling during flight will improve dramatically .
