Originally Posted by
DelGatoGrande
This is what is was trying to say in my previous post.
With 38%-47% end points your aileron servo travel will have very poor resolution in compare to your aileron stick travel.
"When set up for maximum resolution(maximum end points), the control response is much smootherand more closely matches the precise inputs and intentions of the pilot "
http://www.rcflightschool.com/SetupPDFs/Resolution.pdf
Maybe if you try drill a new hole on your servo arm as closer you can to the servo arm center so you can increase your %-% end points .
The your Aileron feeling during flight will improve dramatically .
George,
thank's for information, but we check aileron movement - it's looks very smooth (maybe it just first view). Anyway, will check these on maiden, in case will it be uncomfortable will rebuild.
So the PC-21 is not 3D bird, it's should flight as more scale. I hope everything be OK.
On my UltraFlash the same servo travel (39-45%) plus 45 Expo and I like she's flying.
The servo horn has maximum length to be inside wing now, with maximum possible hole from center for pushroads.
Kind regards,
Sergey
