Tygon is a little stiffer to work with and tends to very slowly harden a bit with use and age while
silicon tends to be a little nicer to work with but tends to slowly soften and swell with use and age.
As noted above if silicon is used with gasoline, pump diesel, kerosene or Jet A it will rapidly swell and soften becoming unusable in a very sort time.
John
