Originally Posted by
helifox
George,
thank's for information, but we check aileron movement - it's looks very smooth (maybe it just first view). Anyway, will check these on maiden, in case will it be uncomfortable will rebuild.
So the PC-21 is not 3D bird, it's should flight as more scale. I hope everything be OK.
On my UltraFlash the same servo travel (39-45%) plus 45 Expo and I like she's flying.
The servo horn has maximum length to be inside wing now, with maximum possible hole from center for pushroads.
Kind regards,
Sergey
Hello Sergey,
actually the 3D planes do not have good resolution because of 3D setup.The best knowledge in resolution setup you will find it in precision aerobatic planes like F3A and helicopters.
When you have wide end points ,meaning wide servo travel in compare to the stick travel, then you can experience a superior feeling while flying the plane.
In the SkyMaster F-104 i did hidden links like you i drilled new hole on the servo arm closer to center to gain resolution.I attach you photo.
All the best with your maiden my friend.
Paka from Greece
George
